1970 blazer
5 Attachment(s)
Can you guys give me an idea of what you think this blazer is worth? I have been wanting to start a project for a while. I have a good idea of how much I will have to put into it and how much I'm willing to spend on it - just want to get another opinion.
It has a 350 in it and is not running. Thanks, Tom |
Re: 1970 blazer
5 Attachment(s)
more photos
Re: 1970 blazer
5 Attachment(s)
last one
Re: 1970 blazer
Thats basically a parts truck to me. Nearly all sheetmetal is shot, I'd offer $100 over scrap value. Thousands and thousands in body work.
Re: 1970 blazer
It all depends on how much your willing to do and if you can do the work . Good luck
Re: 1970 blazer
I'd offer $500 if you really like to cut and weld patches. Otherwise I'd walk away.
Re: 1970 blazer
Re: 1970 blazer
More than $500.00 worth of parts setting there.
Re: 1970 blazer
just get it... and built your own RAT!ROD.... ! Dont be scare of rust... RUST IS NOT A CRIME
Re: 1970 blazer
Redeeming factors include:
Stock Buckets Stock center console Stock A/C component, including compressor Np205 (27 spline input, which is easier to get adapters for than 10spl) Rally Wheels with trim rings Hard top (double wall) with hatch and glass Front fender and hood look decent uncut dash tailgate, doors, glove box door, ashtray upper radiator cross over tube original block/carb? but definitely a lot of work on the tub.... however, I don't see anything (yet) that is not fixable. How is the windshield frame? How bad is the rocker box, etc.? How bad is the firewall/cowl? I'd guess $500-$1200 but price is so subjective. It is a buyer's market... |
Re: 1970 blazer
Think to part out 500 so you can make a little on it for rebuild i bought a 70 gmc solid body little work on floor running smoke when first cranked with single wall top 350 custom leaks oil transmission fluid but run and drives good for 2500. Would not want to tackle the body work good parts blazer.
