rear mounted Fuel tank?
when you moved you fuel tank to the rear, how do you fill it?
any pictures would be great too.... |
Re: rear mounted Fuel tank?
A lot of guys will run a door in the bed, which will give them access to the filler cap on the tank. Or have a filler cap directly on the bed floor that is tied right into the filler of the tank.
http://www.azproperformance.com/Boyd...ill-14001.html Here is the Boyd tank. http://www.azproperformance.com/images/P/14001-1.jpg Some filler ideas... http://image.customclassictrucks.com...et-c10+bed.jpg http://image.truckinweb.com/f/brandp...bed_detail.jpg http://image.truckinweb.com/f/featur...et_c10+bed.jpg |
depends on the tank just how you fit it.
Search this site for more info. there are several threads dealing with how, and where and the types of tanks available. All very good info. It not a big job, but will take prob. a weekend to do. Good luck. |
Here in sunny Oregon (not) we cannot pump our own gas. Someone leaning over the side of my truck to fill my tank doesn't thrill me so I installed mine as shown.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Here's mine:
For real you cant pump your own gas...?? What the heck is up with that. Posted via Mobile Device |
made my own tank and filler assembly
http://i290.photobucket.com/albums/l...e/DSC02228.jpg http://i290.photobucket.com/albums/l...e/DSC02229.jpg http://i290.photobucket.com/albums/l...e/DSC02230.jpg cut this assembly out of old behind seat tank and modified it to fit http://i290.photobucket.com/albums/l...e/DSC02232.jpg this was out of a japper http://i290.photobucket.com/albums/l...e/DSC01877.jpg |
2 Attachment(s)
Here is what I did, cut the filler out of a 96 Silverado
some people and there is a thread here put it behind the tailite or behind the side marker lite, so many good ideas and so few trucks.
Thank you for all of the replies...keep em coming!:metal:
2 Attachment(s)
Here is the factory aux. tank filler installation, essentially but not exactly a Blazer setup.
Does anybody know where i could find this setup?
http://www.classictrucks.com/feature.../photo_03.html |
I made a filler pipe to stick the cap in the left rear corner of the bed floor , that way the bed floor is still useable , without going thru the bed side , filler , or taillight.
i got the boyd tank but had my filler nozzle run to the side marker light and we made the light a gas door so its hidden. were still working on it but heres it on the truck with out the bed
Do you have any pics of this set up? It sounds like that you did it the way I've been thinking about. |
2 Attachment(s)
Heres mine made from a race car latch, hinge and steel plate. the bed patch in front of the fuel door is for fuel line and in tank fuel pump access. Homemade alum tank with vented Speedway sprint car cap and bung.
3 Attachment(s)
44 gal suburban tank in mine,,when its half full I still have more gas than the stock tank!
2 Attachment(s)
cleanfreak.
Thanks. That's almost identical to what I was thinking. The only difference I was thinking about mounting the filler higher in the bed. My way is a little more clunky looking. My other idea is to do a flush mount gas cap (from a custom motorcycle) in the stake hole. I can't make up my mind. |
If I would change any thing , I would raise the cap a bit. It fills well , but the fuel splashes back a bit if it isn't angled perfect. Another 12" , angled cap towards the inside , might work better.
That's exactly what I was thinking about doing. I think what you did is cleaner looking but up higher is a little more practical. Hopefully I can get to somewhere that I can start that project and I'll post up my pics. It's kinda hard to work on the truck in a hotel parking lot.
anymore pictures on this????
I don't care for any of the in bed fill location Ideas, and most of the side fill have been kinda crude looking (my opinion) except the nice fill door, body & paint work shown. Just a lot of work though.
I was at a local Hot Rod shop the other day and the Shop Manager swore there's a modifier kit he saw that uses the rear side marker light as the fuel filler access door. He said you push in on it and it pops open (outward). I'm pressing him to find the info on it because that might push me over the top to doing a tank relocation myself. |
Yes I know their is no cap, but if you have some wheel gap to play with you can't see that at all
