Pro-Touring S10
We're starting a new project here, our first 'mini' truck. Our goal is to build a capable autocross/road coarse truck without loosing all of the street manors, and do it on a budget. We bought this 94 shorty, with no motor/trans for $300 bucks. We've got $220 back from parts sold off. First we gutted it, down to the bare shell. Then we started with a plan of action. 6.0 LS, camaro 5 speed, low, fat, big tires all around.
Re: Pro-Touring S10
2 Attachment(s)
Our first thought was urathane or solid cab mounts. Wait, do we need cab mounts? We unbolted the cab and set it down, it almost clears. Some parts of the floor hit the frame. Hmm, we carefully notched the floor and set it down. This is the first drop. 1 1/2" down. We carefully aligned the cab to the chassis and bolted the corners down, then welded the floor to the chassis. Yes, this may increase the road noise, it will also strengthen the truck as a whole. We're going for it.
Re: Pro-Touring S10
Getting the bed down was a little more work. For the front mount, we cut the top off of it and fabbed a new top plate to be welded on. The second mount is welded to the side of the frame, so we cut it off and re-positioned it, then welded it back on. For the third mount we notched the bed crossmember and put the nut plate back in place. And in the back, we notched the back of the frame down and welded a new tab on. We also moved the bed forward to fit the cab better.
Re: Pro-Touring S10
The downside is that a part of the bed floor hits the frame rail, so we cut it out. It barely comes through the floor, about 1/8" above the bottom floor ribs. But we need a little more room. We are planning a small 6 point cage and our rear bars will attach here. We welded a 3/16" thick bolt plate to the to of the frame. The top of this plate is about 1/16" above the top floor rib
Re: Pro-Touring S10
2 Attachment(s)
Next we need to fix the bed floor. We fit a peice of 18ga. to cover the hole. It has four holes in it that line up with the cage plate. next the cage plate goes on. Our goal is to be able to unbolt and remove the rear cage bars, and the bed, just in case we need to late on.
Re: Pro-Touring S10
2 Attachment(s)
One reason we moved the bed forward was to close the gap for the cage pass through. We set the bed with a 1/2" gap between thefront bed panel and the back cab panel. The cage mount plates fit on either side, with a 1/2" thick aluminum plate in between the two panels. When it's bolted up tight it's rock solid.
Re: Pro-Touring S10
This is going to be one wild truck!! I need to bring my S10 to you as it needs some serious street manners after I put the 5.3 in it :lol:
Maybe I need to slow down a little ;) |
Re: Pro-Touring S10
I wanna watch!
Re: Pro-Touring S10
I have always loved s-10's, it's nice to see one getting some auto cross love:)
Posted via Mobile Device |
Re: Pro-Touring S10
The frames on these trucks flex and twist alot, so hope you dont get a distortion until the point the doors wont close right.
But.. interesting build, looking forward to seeing the build! Posted via Mobile Device |
Re: Pro-Touring S10
Re: Pro-Touring S10
As part of the plan to stiffen the chassis up a bit, and add some driver safety, we are building in a 6 point cage. The rear section is made to be a bolt in so we can take the bed off later. We are using 1 3/4" x 120 wall DOM for the main bars. The X-brace is 1 1/4" 120.
Re: Pro-Touring S10
3 Attachment(s)
For the inside of the cab we are doing a simple main hoop and door bar. We will be adding a bolt in diagonal bar after the seats are fitted. We braced the floor with 1/8" plate, tied to the cab mounts and chassis, this gives us a strong location to mount the cage to. As we said, this is for chassis strength and safety. It may seem like too much for some, but if you've ever been down the long straight at ButtonWillow, (raceway) you would want one.
Re: Pro-Touring S10
Nice work! Are you guys going to cut the front frame horns and lower then down to match how much you lowered the body? That would bring the body and bumper down to match while allowing the front sheet metal to float like factory on the bushing.
Re: Pro-Touring S10
how will cali smog affect it?
Re: Pro-Touring S10
Cool Stuff, I'll have to watch this one. I always like Rob's stuff.
Re: Pro-Touring S10
Re: Pro-Touring S10
looks like its going to be awesome.
how low will you be when your done. this is my old s10 that qa1 coil overs drop spindles and dearched leafs with a 2 inch block. then alignment shims for the pinion and carrier. http://i283.photobucket.com/albums/k...kes10Large.jpg http://i283.photobucket.com/albums/k...uck/truck2.jpg |
Re: Pro-Touring S10
thats what i was wondering. dang smog requirements
Re: Pro-Touring S10
Set the motor in yesterday. Hmm, no go on the truck intake. Our body is almost 2" lower to the chassis, I guess that does it. car intake it is. We also decided to set the motor back a bit, Less than it looks like, about a 2" setback in the firewall. We aren't using the A/C, and we'll be putting in a universal heat/defrosester inside. More fitting up later today.
Re: Pro-Touring S10
Re: Pro-Touring S10
Tuning in!
Re: Pro-Touring S10
I like the direction this build is going. I have a '96 s10 ss that I've threw some poly at, it handles pretty well with the zq8 suspension package. Have you checked out www.protourings10.com?
Re: Pro-Touring S10
This oughta be fun. I gotta see this. It'll be fun at Adams, that's for sure!
Re: Pro-Touring S10
Here's today's project. Take the bed sides off. We started by unbolting and moving the bed back, and then drilling out all of the spot welds. This takes a while. We start with a 1/8" hole all the way through, then a 11/32" bit 1/2 way through. Last step, the inner fender underside needs to be cut loose.
