Just got my LS rad check it out
2 Attachment(s)
Just got my LS rad check it out, should fit just have to get 4 row mounts and maybe small mod.
Re: Just got my LS rad check it out
Nice looking set up.
Where's it from? Kim |
Got it from summit it's a Griffin rad, Came with relays and temp sensor for head.
http://www.summitracing.com/parts/gri-cu-70013-ls |
I like that. Even better Griffin is made in the USA. Thanks for sharing that.
Posted via Mobile Device |
What rad hoses are you planning to use. Same with trans lines. I'm at the same cross roads determining which rad to buy and hoses/lines to connect everything.
Such a great price! I just added it to my wish list on summit... LOL
Was it complete with the shroud and fans, too? I was leaning toward using my stock radiator and shroud, but may go this route for the price.
That's pretty sweet. I may have to order one.
Is this part number GRI-CU-70013-LS from Summit? I'm hoping so, because that is what I have ordered and it's scheduled to be delivered today! Looks sweet from your pictures.
Edit: Nevermind, I saw where you listed the part number above, and I just missed it. I didn't understand how they have things priced either, but I'm glad it worked out well. |
Looks like a great deal. Can you post pictures of how it mounts once you get the new 4 Core hold downs? Thanks
That part is way more money now! :(
Wow, slight change in price. I'm sure glad I got my order in when I did!
Just out of curiosity, what was the original price?
Parts Total: $459.95
Additional Shipping Charge $55.00 Delivery and Handling Charge $12.95 Total Charges: $527.90 Posted via Mobile Device |
I recently checked with Entropy Radiator and they make a similar setup. They didn't have my '57 Chevy pickup listed so I emailed them. They do make one for my application and the cool part is they will set it up for a LS motor with the inlet, outlet, and transmission cooler connections in the right size and placement. The pricing was similar.
Any updates on the fit? Any modifications required on the radiator support? Looking to purchase a unit but getting info is hard. Any help.
2 Attachment(s)
Got mine installed last weekend using the 4 row mounts. Just some slight trimming on the rubber bushings and a quarter inch spacer under the top mounts.
I like it Jason. So the bottom fit in okay, or some trim needed?
Is that the steam line beneath the upper hose? |
