68 shortbed 5.3 4l60e DBW swap :)
Yessir.. I'm starting this thread to help.. (Show off my work) lol I have a 68 Chevy c10, putting an 04 5.3L 4l60e in it... I had a 350/350 turbo.. I have done lots of research before the build... I got motor/trans PCM harness tac gas pedal for 1300$ motor had 62,000 miles on it... I live in Dallas Texas... These motors are very easy to find... I got a custom grind to cam.. Got some springs and lifters ... Professional valve job... Got the harness modified locally.. Can hook u up w number if interested.. Got PCM flashed from ol boy from lt1tech , quick turnaround.. Real good guys..
Pix coming soon I dropped motor and trans in today and it fits perfect. 5.3 manifolds didn't fit, I'm using dirty dingos and the pedestals that came with the truck when I got it.. Had 350/350... So gonna try the tbss manifolds? What year guys?? Driveshaft fit... Awesome!! Mounting fuel system tomorrow.. Got the vetted filter and a external fuel pump... Have a 18gal tank under bed ( came with truck) for now at least... Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Re: 68 shortbed 5.3 4l60e DBW swap :)
Only letting me one at a time
Bat
did you use the stock oil pan?
So the stock driveshaft length fit just fine in the 4l60??
Any chance of getting a picture of the driveshaft in the trans? |
I uzed the dirty dingo mounts with my engine all the way forward mine was 3 inchs to long i went a head and slide the motor and trans all the way back and had 6 inchs taken out of my front shaft.
Dude, Subscribed. I wanna see thin thing running.
Seth |
Where did you get the motor and transmission from?
motorandtransfromjunkyard
you have one clean truck. who did the cam swap for you. an what part of dallas
northTexas machine.. I'm inIrving
a1 engines and transmission in off Davis and loop12 |
Far out! more pics of the truck when you get a chance.
Are you running the 350 trans ?
what cam and springs are you using ? truck looks clean I had major issues with manifold/headers using cpp's pedestal mounts had to modify a set of pacesetter headers to work , did not want to fork out the coin for dougs headers |
I ended up using stock 5.3 manifolds.. had to grind a little on passenger. side I'm using the sbc stands and dirty dingo adjustable mounting.plates. I have motor as close as I could to.fire wall |
