Just got this engine for $1300
All new. I do not have a ton of experience buying engines but I figured I could roll the dice for this much. What do you think?
87-95 series 350 (5.7) Four bolt main, bored 40 over, Moresa pistons, cast iron rings, Engine Tech lifters, SA cam, 10 under rod, 10 under main, 10-10 crank, machined heads, SA timing set, spread bore Edelbrock manifold, Mr. Gasket oil pan, valve covers, timing set cover, all chrome. 2 inch crank for flywheel, gasket set for accessories Attachment 1108483 |
Re: Just got this engine for $1300
good find. It should be a great powerplant.
I am really looking forward to finding out!
I would do some spot quality checks.
Some easy spot check examples: Verify dip stick level indication correct. Verify lifters adjusted to spec. Verify #1 TDC lined up correct. Verify >50psi oil w/ drill prime. Verify oil flow to valve train w/ drill prime. Verify head bolts don't turn when torqued to spec. Look closely an intake end gaskets/RTV. Note quality of gasket/RTV application. Drop pan and verify all crank bolt torques. Verify oil pump bolt torque. Verify crank clearances w/ plastigauge. If all pass and I'm feeling lucky I'd consider startup. |
I recommend you put a starter on it, a ring gear and compression test before you do anything much just yet.
If the numbers come out nice and fairly even, then I would proceed with all the fun stuff!! Good Luck, keep us posted! Coley:chevy: |
Start with a cylinder leak down test. It will tell you far more about the condition of the engine than a compression ever will.
I have been watching Boise craigslist for a long while to find a deal like that. good work
Hi tim, i thought i was the only one to use a cylinder leak tester! 10% loss or more equals more checking and possible trouble. Is my memory correct? I just joined a week ago but you must have worked in repair shops also, as i did. Brian F.
Thanks guys, I will do it all!
Good price on that.
It's difficult to get a good gasket seal on those chrome parts. If you "rough up" the mating surfaces of the chrome parts with fine sandpaper, the sealer will get a better bond. Otherwise plated pans, and front covers notoriously leak. |
Good to know, thanks!
