Gears on 5.3 swap
Just wondering what some of you guys are running for gears behind your 5.3 swaps and what your tire size is.
Re: Gears on 5.3 swap
I went with the 3.42 ratio. This was the gear ratio in the '08 GMC donor truck. Still working on putting the truck together.
Just going by the 02, she runs way getter with the 3.73's (29" tire). Longhorn
I have the 4l60e and I used to run 3.08's and it bogged a lot on highway. now i run 3.73's and it has a lot more bottom and highway driving is much nicer too.
I have a 3.42 with a 4L60e and a 29" tall tire. I had this tire & rearend in my last vehicle with a 700r4 and I didn't hate it, but I do wish I'd a gone with a 3:73.
Posted via Mobile Device |
Well that makes me a little happier. I found a posi unit (4 series) with 3.73's in one of my extra rear ends and was thinking they may be to high for the 5.3 but i guess i'll be rebuilding that one now. Thanks everyone.
Truck doesn't have the 5.3 yet.
I'm going to swap in the 5.3/5-speed tranny first, then drive it with the current 4:10 ratio long enough to determine what the best ratio would be. This should avoid any "I shoulda/coulda" type regrets, or multiple experimental swaps to find what works best. |
Try a gear ratio calculator... plug in the blanks and it will tell you RPM at MPH ...
http://www.summitracing.com/expertad...tio-calculator |
I have a 6.0 with 3.42 gears. I am sure that 3.73's would bring her performance up, but honestly she has plenty of pep already and even with the 4l80e tranny I am still getting close to 19 mpg. I am more than happy with both.
My 71 2wd Blazer with 5.3 and 4l60, 3:73 is pretty tough.....I think that it would spin the tires all the way through 2nd gear. The acceleration with the 3:73 is really fun. I am running truck rallys with 275/60 R15 BFG
lq4 6.0l/4l80e, posi 3:42 gears 28" tire.... 1900 rpm @ 60 mph.
4.10s + 4L60E with 315/35/20s = Fun. It will be a little more fun once I get a higher stall converter too. I'm sure its costing a few MPG, but I have 1500 miles on it in 3 years....so I'm not too concerned (still get 16+)
