327 to 5.3 engine mounts wrong DD mount??
Im doing a swap on my 67 I came across some dirty dingo mount not the sliders the Truck ls mounts I no I seen someone using these I cant seem to find the rubber mount that goes with these
Or should I just buy the sliders I would really like to keep my drive shaft and dont mind triming the frame alittle its going to be my DD thanks for any help |
Re: 327 to 5.3 engine mounts wrong DD mount??
Attachment 1120172
I think I have didn't perches the po must have swap them. So now I need to find different ones correct or. Is there a mount I can use with these. Thank Posted via Mobile Device |
Those are the older style mounts. You need these and these
http://www.ebay.com/itm/390560369965...ht_3251wt_1162 http://www.ebay.com/itm/330933769089...ht_1934wt_1400 |
I'm fairly new to these swaps but I will give my best answer. Those Dirty Dingo engine mounts are designed to work with the 73-87 engine stands. If you would like to keep your current engine stands you would have to purchase the mounts and adapters from the post above. Many people switch to the 73-87 engine stands when using the DD mounts or use aftermarket stands like the POL stands.
Picture of the 73-87 engine stands in this thread: http://67-72chevytrucks.com/vboard//...ad.php?t=93121 POL stands with motor mounts: http://www.performanceonline.com/196...RACKETS-16820/ Both options are pretty much bolt in. I believe you only have to drill an extra hole or two. Hope this helps! |
Got it. Thanks guys for all the help.
