1965 c10 Tailgate removal
I am in the process of restoring my 1965 Fleetside C10 an am having trouble trying to work out how to remove the tailgate? please help!!
Re: 1965 c10 Tailgate removal
Welcome. The guys in the 60-66 section may know better than us. Good luck with your project
Posted via Mobile Device |
I moved this to the correct forum for ya.
here it is first there is a bolt under the tailgate that i believe is 9/16" that will have to be removed on both sides of the trunnions, then lower the tail gate and make sure you have someone there to help you hold it while you take off the upper bolt which is 9/16". Once that bolt is out the trunnion plate holding the tail gate will slide up or down to allow you to remove the tail gate. |
