63 C-10 Panel wiring harness
Hello there...:hiya:
Need to replace the complete wiring harness on a 63 panel I'm working on and would like to know what wiring harness you guys are using? I have used American Auto Wire in the past (60-66 Chevy truck - Classic Update Series) for a 60 step side I own and would like to use it again but no sure if it will work for a panel truck. The kit cost a pretty penny so I need some imput before I pull the trigger...Called AAW and the sales rep says it should work but he was not convincing. I know the cab is the same but the rear body and truck chasis not sure.... I also know the kit comes with long enough wiring for different truck bed applications. Please help fellas... |
Re: 63 C-10 Panel wiring harness
Call AAW, they will build it to your specs. length accessories etc.
You will only need extra wire for brake/tail lights, dome light and fuel sending unit right? |
I used AAW on my 63 Burb without a problem.
Posted via Mobile Device |
