mini road trip drama
Took a drive to Hollister today to drop off a dresser for my grand daughter( Didn't have your number John)
Hollister is about 45 miles away so this would be a maiden trip since putting in the 3.73's in. She drove nice 185 degrees on the temp gauge oil pressure fine too but I noticed the brake pedal was a bit hard, and had hardly any play not allowing the brake light switch to work. I pulled over and adjusted the pushrod and was back on the road. 10 miles down the road get the same hard pedal. Pulled over again and readjusted it again. I noticed the dust boot was bunched up, too small and the push rod was not "sliding" thru it. I pulled the boot loose and off I go the problem didn't come back. On the way back I get a little weird idle problem and the there is a little popping on deceleration. but she is running fine. Other then my cd player going out there was no other problems I get home and lift the hood and notice my vacuum line has come loose from the carb ,and has broken off from the vacuum advance. What would a road trip be with out a little drama ? Good guys show next week will see how she drives then. |
Re: mini road trip drama
I love hearing these stories! Thank you for sharing. Most folks these days would wither up and die at these problems. I love that we make the necessary adjustments and "keep on truckin"!
Cant wait to take mine on a voyage... Have to wait untill the 31st to get the new tags.
These annoyances are what make driving our rigs fun. For comparison, I have a 2003 Sonoma I bought in Feb. 2004 and have driven it about 24000 miles as my daily driver with absolutely no problems. BORING is how I refer to its driving experience! (Now, could you call that sarcastic?)
Sam |
Congrats Sal!!
You gotta luv those first time white knuckle road trips. I've had my share. Soon I'll see you cruisin' my street! LOL!! |
THe plus would be free room and board for a week ot two when you got here!! LOL!!
It's in my signature .... been there for a looooooonnnnggg time !!! (and here I thought the Portagees were the ones with all the excuses) |
No way !!! Dang I need new contact lenses ! How are things at the shop
When you swapped gears, did you by chance give it a brake job, too?
I swapped the whole rear end... the Dana 44 I had in my '61 ate itself and junked the housing. I had a new housing and 3.42 Posi set up, and then rebuilt the drums on the bench so I could swap min a whole new rear end. I put the shoes on backwards, and they were dragging... I experienced the exact same issue you did: real hard pedal after driving for a while. The shoes drag and build up enough heat to expand the brake fluid, which makes the pedal hard. -Brad |
What was strange is after I pulled the dust boot off of thr mastercylinder all has been fine.I'll pull the drums off and check it out. Thanks for the tip . |
