Vss plug help
I am having to install a pulse generator for an engine swap. I am looking for a receiver plug so that I can have a quick connect, and not have to butcher my wireharness. Has anyone seen a plug like this? It is the one that has the 2 latches on each side. Not the single between the two prongs.
I'm not opposed to getting an "extender" or "adapter" harness, and butchering it up. Just don't want to butcher my stock harness if I don't have to. Plus it will just make it look cleaner. |
Re: Vss plug help
I don't have an answer, but here's a bump so people will see your quesiton.
Re: Vss plug help
thanks for the bump. Found one on tpiparts.net I think it was. Was actually on ebay, but that's the company I think.
Re: Vss plug help
AutoMeter makes a hall effect style Speedo adapter to give you a VSS circuit.....it plugs into the trans and your OE Speedo cable screws onto it.
Re: Vss plug help
Lots of companys make them. dakota digital, painless wiring.
I wanted a pigtail so I didnt cut the harness, i already have the signal generator. |
