Getting Fuel to Carb
I am working on my brother's '69 GMC with a 305 V6. I can not get it to start but it tries to start with starting fluid so I am starting to think that it is not getting fuel. I by-passed the fuel filter to make sure that was not it. I also checked to make sure the sending unit was not clogged. How long should it take the fuel pump to get fuel to the carb?
Re: Getting Fuel to Carb
Less than 30 seconds. Pull the fuel line from the carb and put it in a quart bottle. See how long it takes to fill.
Are you getting spark? |
Yeah I'm getting spark. It has a new distributor, cap, button, wires, and plugs. I'm trying to get the timing done but I can't do that since I can't get it started. This simple fix has been a pain in the a$$
You should be able to get the timing kinda close while cranking as long as the battery lasts.
is this an hei or a points type distributor
Points Type. I have not found a HEI type that will work with this engine. I will try to time it as someone cranks it. I will probably try an electric fuel pump.
How much fuel psi does this engine need? 5-9psi?
set your points
The distributor came with pre set points but I will double check them tomorrow.
