Bowler Performance Tru Shift Throttle Correction System
Bowler "TRU-SHIFT” TV CABLE CORRECTION SYSTEM
For 700-R4 & 200-4R Transmissions http://www.pro-touring.com/attachmen...5&d=1389216957 67-72 Forum Pricing $229.95 Are you tired of the trial and error method of adjusting your TV cable on your 700-R4 and 200-4R transmission? We at Bowler Performance Transmission sure was! That’s why we developed our own kit to solve this problem. When you purchase one of Our TRU-SHIFT systems you will get the easiest and best functioning TV cable adjusting system available. When you install this system you simply, bolt on the supplied bracket and carburetor cam assembly, install the Bowler TV cable, then run the accelerator to wide open throttle the cable will automatically adjust itself and you’re done. With this system there is no need to remove the carburetor, no cams to adjust, no need to drop the transmission pan, no need to install a pressure gauge to check the pressures and best of all no more guessing. Bowlers even include different throttle cable brackets to cover Lokar, Gennie, GM square and early round hole. Each one attaches neatly to the supplied bracket. We have kits available for Holley, Edelbrock , Demon, MSD & Quickfuel Carburetors. ** Note: If you have a Quickfuel Carburetor we will need to see pictures of the base and the cam. Please email us pictures at jon@bowlertransmissions.com or call us at 618-943-4856** |
