wanting a smooth firewall, where should i mount clutch master cylinder?
so im about to order a frame mounted brake booster from scotts hotrods, but then i saw their under the dash unit that can mount the booster, also the clutch and brake cylinder. i like the the idea of frame mounted to eliminate clutter under the dash as i will also have vintage air under there to. so i was wondering of a good way to mount my clutch master cylinder if i went and got the frame mounted booster kit. or would it be eaiser to do the under the dash setup?
Re: wanting a smooth firewall, where should i mount clutch master cylinder?
Justin |
Sorry but it's atually gonna be on my 72 c-10 if that makes a difference
do you guys at scotts have pics of the underdash unit mounted?
