Early Classic Enterprises
Hello,
I own a 1966 GMC Suburban. We are putting a LS1 in it. I've been looking for a replacement gas tank and ran across Early Classic Enterprises gas tanks. Has anyone used there EFI gas tank on burb? I see were Boyd's Welding is has been used on a couple Burbs in the forum. |
Re: Early Classic Enterprises
I ordered a gas tank for a 1990 suburban.It will allow you to put pump in the tank. The tank fit in there very nicely.
Thanks Licfer,
We're did you get the tank at? Is it a stock tank? Do you have any pics. Thanks |
Attachment 1219048 |
Thanks Lucifer,
I guess you had to move some frame rails? Did the fill match up to the fill door ok? |
Attachment 1219055 |
Thanks Lucifer,
Did it require any changes to the interior floor? |
Nope in fact there is 1 inch of insulation on the
Bottom of the floor and still no interference |
Thank you sir,
I think I'm convinced. Do you have a thread on your build? |
No never did one and I regret it
Thanks to bad. Can you post some pictures of the rear of the burb? I want to see how the tank hangs down.
Thanks for all the advice. |
I will get sum tomorrow
2 Attachment(s)
Attachment 1219272 Attachment 1219273 |
thanks for pictures. What a nice Burb!!! I'll trade you right know :)
Lucifer |
Lucifer,
is your Burb bagged? |
here is a picture of mine Burb (hope i did this right)
regards |
Thanks Lucifer,
they are Coy Wheels. |
Nice setup. Definitely have to remember this if I ever go EFI. :)
Thanks for sharing the info! |
if you can afford to go EFI you should. I love it, I had it done on 55 and the thing runs great. I would recommend Speartech for you wiring harness.
Hi Red31005, nice to see another old Burb close to home.
Thanks MikeS
Got any pics of yours? |
