Re: 72 Blazer part out
Interested in wheel wells let me know price, thanks
I like to buy that booster bracket from you. Circled in red.
Interested in the below items if the price is right, shipped to GA 30005
1) Rear side panel mount brackets - center top hat type - floor and tailgate L type - I think they are spot welded 2) firewall to rear wire harness - any cuts or breaks? 3) Rear bench rear hold down bracket and bolt Thanks Jim |
Interested in the last 4 or 5 inches of the bed/deck leading up to the tailgate.
Thanks, Brad |
Bob |
I see that you have several 67-72's. Would you happen to have a passenger side sport mirror?
Thanks. |
Interested in this section. Thanks - Tony
Interested in both front floor sections if they are solid.. Does the passenger have some extra holes drilled in it?
On second thought, if shipping is doable, I really need to get the back half of the rear deck. So I'll revise my request to: interested in the deck mid wheel well to tailgate shipped to 30622 vs. just the last 5 inches leading to the tailgate.
Thanks, Brad |
how much for the interior cargo panel metal brackets on side walls and floor.
Metal bracket for vacum canister on ac housing shipped to 48817
$80 plus the ride...
$22 plus the ride....
Please clarify these before I can price...
1) Rear side panel mount brackets - center top hat type - floor and tailgate L type - I think they are spot welded I will confirm condition and let you know 2) firewall to rear wire harness - any cuts or breaks? $15.00 shipped if going with other items 3) Rear bench rear hold down bracket and bolt Quote:
2 Attachment(s)
Here's the rear panel brackets I was interested in. The center ones should only be held in place with screws. The side ones may be tack welded, not sure.
Attachment 1226546 Attachment 1226548 Thanks Jim |
second inline...noted
If Greyhound is an option for you...$100 for the cut and what ever Greyhound would be...
Adam Quote:
Might have another above you wanting a couple of those....will see what he says first.
$21.50 shipped
11 brackets total, $100 shipped, and will do combined shipping if the wiring harness and other request are a done deal.
Can you send a picture(s) of all the parts off and together, so I can determine condition? No rush, when ever time allows.
Thanks Jim |
OK, let me get to tearing this thing apart and get a quote from Greyhound...
More than fair...let me get to tearing it down!
