84 K10, Battery? Starter? Ignition Switch?
I changed the fuel pump today, after going to start the truck I ran into a couple problems. I couldn't get it to start, I cranked it many times, pumped the gas a bit then all of a sudden nothing.
I'm not sure what happened but it was cranking fine then all of a sudden I got zero response from the ignition. I still had lights and the voltage gauge was reading something close to 11 or 12 volts but no starter reaction. I left it alone for a while thinking I may have overworked the starter but when I came back I noticed turning the key would kill the power in the truck for a few minutes, I noticed this when the dome light cut out and kicked back on after a few minutes. So, did I kill the battery, starter, or is there a short in the ignition switch, and how do I figure out what's wrong? My truck is stuck in my apartment complex's lot and I can't have a disabled vehicle parked here for too long so I would appreciate any help to get me mobile as soon as possible. Thanks. |
Re: 84 K10, Battery? Starter? Ignition Switch?
check the fusible link
Sounds like a bad battery connection. Check for corrosion and being tight.
I had the same problem about a month ago. Check your battery cables and also the cables running to and from your starter. Somehow my starter cables developed a bad connection. Good luck
The cables will run right from from the side of the starter. You'll probably have to crawl under neath to get to them. Also check your fuses. The cover should have a diagram showing what fuses go where.
I know in my 79 there is
