Paint break line on cab
Painting the top of my cab white on my 70 short step. Anyone know the measurement on where the the white stops below the back window and around the sides by the drip rail? Is it better to just hang the doors, mask it off then remove for paint?
Re: Paint break line on cab
Dude, You provided the measurements (and pictures) to the same question about a week and a half ago.
http://67-72chevytrucks.com/vboard/s...d.php?t=620739 |
Yes sir I did but want to confirm these measurement with others to be sure. We are fixing to paint cab and want to b sure it's 100% correct
4 Attachment(s)
Maybe these will help. Remember if you have the studs they are most likely factory installed. So even your pictures locate the lower edge and the stud centerline. The paint wraps around the back of the cab split under the molding then drops to the bottom of the drip rail and turns in to create the jamb split point. On the door its easy white down to the door skin.
