Cluster lights, can't figure it out
Ok guys I have tried everything I have no where else to turn and I'm hoping someone has experienced this problem before. When I turn my lights on the only lights that come on in my cluster are my turn signal lights and I don't understand why, they are just on at a constant they work just fine and one day I was wiggling stuff around in the blinker switch and bam the lights came on and everything went to normal the cluster gauges all lit up and the turn signal lights turned off. Has anyone experienced and fixed this issue? It's driving me nuts.
Re: Cluster lights, can't figure it out
Check your ground. I would just run a new one.
I just cut the ground ran a new one and it didn't change anything. Think it could be the blinker switch?
Something is not right I cut the ground and tried the lights with the ground cut and the blinker lights still turned on. I'm at a loss as to what to do
