Power Steering Pump Adaptation to GMC V6?
Any info or pics from folks that have mounted a later model pump to their GMC V6 engines? Working on my power steering conversion and would like to buy a pump...just curious if I am fabbing it all or if there is a combination of brackets that work?
Re: Power Steering Pump Adaptation to GMC V6?
5 Attachment(s)
You need to try and get the double groove pulleys for crank and W/P. That is half the battle.
Here is something I fabbed up using this EBay bracket and I think a Buick double groove P/S Pulley/Pump. I had a friend make me an extension to bolt up underneath. My fab skills are basic but this works. I have also seen some use the chevy big block type of pump with remote reservoir. |
Yes, I've seen some people use an idler pulley as well.
There are 2 different size double grove pulleys that came on the V6, there also 3 grove pulleys.
If you are interested, I have a V6 power steering pump, brackets and pulleys, and adapters for steering box-to-frame.
Ahaynes; The extension on bottom is offset.
The hole I drilled in the bracket arm that sticks out; all I did was remove that front bolt from the engine mounting plate and made a mark and drilled it. The lower extension not sure of measurement. I had to play around with it a bit to have one of the pulleys line up. I'll see if I can get you some better pics and a measurement. |
5 Attachment(s)
Here’s the belt size I used and some extra pics.
https://live.staticflickr.com/65535/...778dc324_b.jpg |
Your welcome Ahaynes;
Your set up looks great!:gmc2: |
