Temp sending unit '59 Gmc
The one that is on my truck is bad, and I have been told that it is the wrong one
The people with the Gmc's can you see if you have the correct one? I'm sorta lost |
Re: Temp sending unit '59 Gmc
Anyone?
I was in the same boat once there should be a number on it
Oops posted before finished I will check my 6 cylinder but I believe the guy at auto parts gave me one out of v8 Chevy but it works
I just wonder if its correct
Quick look online shows the type with a round "t" top for slide on connector. Two part numbers came up PM152 and PM153. I am using the original from my 235 which is that type, next time I go out I will see what the PN is. If the sensor with the right resistance is not used the gauge will read high or low. New ones are $12.
Well I bought one locally from a Good place... Installing it now...Cutting the prong off and putting on the new end clip
