Front coil question
Is there a factory coil out there a guy can use on his truck to lower the front? It is a 67 1/2 ton with 86 front suspension under it. I want it to come down a few inches for minimal cost.
Re: Front coil question
Early Classics Enterprises: http://www.earlyclassic.com/ , Or CPP: http://www.classicperform.com/ ... Both of these are great options... I would probably go with ECE because customer service is miles ahead of CPP Either Mark or Scott are great and very helpful... If you go to CPP Talk to Van at Ext: 112... If you get Javier ask to be transferred (trust me you would regret dealing with him)...
You can also look into these... Cheaper than the other sites.
http://www.summitracing.com/parts/su...olet/model/c10 |
For minimal cost? You can cut one round off the bottom of your coils for approximately 2" drop and save your money for something else.
