do i need high hump
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. |
Re: do i need high hump
What year truck?
2wd? |
2wd 67..
have low hump now.. from what ive read al 4wd and auto-trans trucks came with high hump and havent found anyone that manufacturers them...only full cab floors and i think they are low hump |
If you already have a 4 speed it should be a high hump. AND I have seen trucks with turbo 400s with the low hump without any clearance issues
it had a 4speed and a butcher cut hole in the low hump..
hopefully you are right |
High humps were used in TH400 trans trucks,... which is the same basic size as a 700r4.
I would say you will need a high hump. |
I am also curious about this. I have a 67 2wd with the low hump and I'm going with a RPM 4l80e. I can get a nice high hump for 50 bucks but not sure if I need it...
Thanks for any info! Jason |
