WTB Motor Mounts
WTB motor mounts for '73 - '86 C20/30 truck or, '87 - 91 R2500/3500 truck
Thanks, Billy |
Re: WTB Motor Mounts
Do you need the frame towers or just the mounts? Small block or big block?
Thanks for the reply. I need the frame towers. I can easily get the mounts that attach to the block...it's a small block 383 stroker
Are the towers different from 1500 & 2500? I thought the difference was the motor mount itself. I have a set or towers out of a R1500 suburban - usually sell them for $25 local if your Interested.
I really don't know. Can you post a pic of them? Captain Fab has been helping me with info about what will work. He said that frame mounts from '73 -'87 c20/30 or, '87 - '91 R2500/3500 would work. Otherwise, I don't really know. If you can e-mail me a pic, I'll post it and ask Captain about it.
Thank you! |
fyi, the 1/2 ton towers are slighter shorter as the 3/4-1 ton frames are taller. i have a set for your truck for $38 shipped if your interested. here is a pic..
Don't think those will work for the engine mounts I plan to use. This is a link to the engine mounts I was planning to use and, understand will be the best ones for a higher HP motor. Motor I have is 450hp
http://www.summitracing.com/parts/pt...4-bl/overview/ |
4 Attachment(s)
i need to know if the towers are diff between 2wd and 4wd also.....looking for some for my 69 c10 for the ls swap.
'65 chevy lover, Those engine mounts are for the "pre 73" frame mounts.
lowlyfec10, what are you needing them for a 2wd or 4wd |
