Complete low mileage LS1/4L60E pullout - swap ready
Selling a complete LS1 swap with modded motor and built 4L60E.
Motor has 72k on it, trans has 6,200 miles since build. Motor: Ported heads 04 LS6 cam LS3 valve springs TSP LS6 oil pump Trans: Monster Stage 2 rebuild 2600 converter HD2 shift kit Comes complete as a dropout with wiring harness, full set of f-body accessories, oil pan, car intake, etc. . . PCM has been tuned for mods and for standalone operation in your street rod or muscle car or lawn mower - whatever you want, just add fuel, cut the harness and off you go, no need for more tuning! Note: Harness has not been cut, yet, I didn't know if someone would want it customized to their truck. I can cut it, add an OEM style fuse block and set up for standalone operation for an additional $350 so all you have to do is connect constant and switched power sources and 3 grounds and add fuel for it to run in your swap. $4200+shipping from central Iowa |
Re: Complete low mileage LS1/4L60E pullout - swap ready
What kind of numbers does this do for the engine with the mods? Trevor
It trapped almost 120 in an f-body which makes it between 450 and 480hp based on what online calculators are spitting out. Definitely a strong runner.
If it doesn't sell quickly, would you consider selling the engine and tranny separately? I may have an interest in the tranny.
Sure, $ talks. I have a guy interested in the trans already but no $ received.
I would be interested in the engine myself. Any pics?
I'll be second in line for engine complete minus the transmission.
I can get some tomorrow when I pull it out of the car. Anything in particular you would like to see?
Just got back from pulling this all out.
Its ready to go to the next home. I'll get some pics tomorrow after work. |
Didn't get to the power washer last night.
Will split as follows: Motor, harness, PCM and all accys $3k Trans, converter 1200 Shipping is on your dime. I'm heading to DFW next weekend, anybody in Missouri, Oklahoma or central tx I can put it in the back of the truck and drop it off on my way thru. |
pm sent
..well..I guess it's still for sale beings you have not posted otherwise..
how will you ship? |
Long gone.
