Thermostat housings
I need a 90 degree housing for better hose angle. I have a ls engine and was wondering if sbc are the same?
Re: Thermostat housings
They are different. What about one of these, the straight ones I would think would work great. http://www.jegs.com/p/CSR/CSR-360-De...56559/10002/-1
You can use something like posted above, you can try the GenV camaro pump, or you can bend stainless tube to make the angle then cut the hose to match.
