Vortec 6.0 detectives?
Just purchased a 6.0 Vortec engine from a salvage yard. The yard owner said it was pulled from a Cadillac Escalade, from another yard and swapped to him for a Corvette project of his own. He decided to go with a alum. block 5.3, so, this is the reason I got it. Engine is complete except for starter, alt., and acc. pedal. Engine wiring harness is there but, not very good.
To confirm it is a LQ9, we bore-scoped a cylinder, and it has flat top pistons. The junk yard guy said he did not know miles, or year, but thought 2003. It has the 317 heads, and I plan on pulling them for a re-work and also checking the rods and mains. Here is a picture of the pcm serial number. Attachment 1370113 Here's the questions: 1. Does the computer numbers tell anything about the engine or year of mfg.? 2. Is this computer a good choice for re-programming? 3. Does anyone have a good recipe for budget 400HP LQ9? Will have to use block-hugger headers. 4. Without a vehicle VIN or year, is it going to be hard to get the correct acc. pedal? I'm sure there will be more questions, but, hope you all can answer these first. Thanks. |
Re: Vortec 6.0 detectives?
If it came with an LS, it's worth using. Best when paired with the engine and trans types that it was original to.
Steve, I recommend studying Brendan Patton's awesome website www.LT1Swap.com
He has tons of info that is helpful- Here is his link to identification tips http://lt1swap.com/identify_vortec_engine.htm On another page you will see his info on DBW compatibility on what works and what does not. According to your pic of your PCM, the series number is a 2003 year run. You'll see that on the lt1swap ID page. Also on the DBW page you'll see which pedals and TAC (throttle actuator control) you will need. I am prepping a 2003 DBW harness today and I can send pics of those DBW components and their model numbers if you would like. Shoot me a PM if I can help that way. Education is the best use of your time in the LS game. Im sure there are other great sites as well for more info. HTH Chuck |
This is why those $1500-$2500 ebay "drop-outs" scare me. Thanks, again, and if you or anyone else has a wonderful recipe for budget power, fire away, I'm all ears. Budget is a relative term, I'm thinking $2000-$2500 if possible. That would make me a fairly low buck hot rod. Then, I would KNOW what I have, rather than the ebay engines. |
hello 50 Chevy LS3. if you think that you have the ability to do the harness yourself, id say go for it. its not that hard. I can post pictures of mine when I get a chance. just to get an idea of what you have, take the harness and plug up the harness to the engine and see what pieces are missing. most of the connectors can bought on the net/web and added to the harness. trust me , its easier than you think. as a stand alone harness, all it needs is ground, ignition power, 12v+ constant power, reprogrammed pcm, and all the needed connectors plugged up and you are on the road. I bought a stock DBC harness off ebay, plugged, up all the connectors such as map sensors, MAF sensor, IAC, Injectors etc, added power and ground, and the LQ4 runs great. Of course you need fuel, tranny, tires and some other stuff but I'm sure you get the general idea. my harness has all the original wires. I didn't remove any wires. its bulky, but I only paid $67 for the harness. good luck. pm me if you need any help. ill help best I can. Clark.
Thanks, Clark, you guys are generous in your offers to help.
I think, if I get time tomorrow, I'll get it on a engine stand and strip off the harness and see what I have. I'll take a bunch of pictures and post them so you guys can see it. I know I need a TAC module, and pedal assm., I have the intake piping and MAF sensor. One coil is broken, and part of the plastic engine cover is missing, but, the intake manifold looks OK. I'll try to post a bunch of pics... |
Depending what trans you run, there will be different VSS wiring. You won't need to run a controller though, as the ECM you have can run the 60/65/80 as long as the tune is setup for it. [/quote] I have some answers in bold above for ya. As for getting to 400hp; With an LQ9, 400hp isn't too hard. (did you want 400chp or 400rwhp?) A cam swap with pushrods and springs, and a tune, will get you near 400chp with a good tuner...even with cast manifolds or shorty headers. The cam/valve stuff is around $500, and a tune is ~$350. You can go further in terms of performance, but for a budget swap, I'd consider using extra budget to get a good stall convertor with whatever trans you choose. It'll make you feel faster, run faster 1/4, be stronger, and it's a good thing to buy to match the cam. They can be expensive, from 450-1200 however. I'm tired of typing for now, but if you got more questions, let me know. |
