68 3rd seat belt point mount location?
My interior is upholstered and I would like to find the plug on the first try.
Re: 68 3rd seat belt point mount location?
Im not sure if mine is stock or not but it uses the same mounting location
as the passenger and driver. |
What I need is the dimensions for the location of the upper bolt mount for a three point seat belt.Mine are under upholstery and I would like to hit the hole the first time.
If its cloth try using a needle to find it.
Most of them I have seen have a plastic cap over them. Maybe hard to find with the needle trick. :chevy:
By pressing hard with your finger and moving it around the area I would think you could either feel the caps or the holes (whatever the case may be) through the fabric. They're not super small.
