led lights now dash ind are on....?
I bought the plug in style led (lens') they are the ones that plug directly into the light sockets. I put tail and park lights in now only when the lights are on the dash indicates both front lights are out. I've bought 2 different flashers and neither fix it. blinkers work fine, lights work great. Just when I turn the lights on the dash ind are on solid, don't flash when blinkers are on either. Any ideas?
I was thinking maybe a diode? I have bought flasher from LMC and other one with ground wire..... Not sure if it matters but I have Dakota Digital VHX gauges |
Re: led lights now dash ind are on....?
Those really all need to be replaced to function correctly. You'd need to swap your front indicators as well. The loads for LED'S and incandescent bulbs are very different.
