No crank!
Was going to pull the truck out on this beautiful Easter Day and nothing!
-checked battery/also attempted jump from working car. -removed starter and had checked at parts store -removed ignition switch and checked ohms between ign and solenoid -checked all connections between starter and batt -swapped fuse with known good one (at fuse box) -? Yesterday replaced all belts and did oil change. Drove all Round town with several shut downs and starts, came home, parked and now nothing, no clicks, noise, etc. all other power related items work fine. Stumped and hope I am missing a simple switch or relay? |
Re: No crank!
check the neutral safety switch
Re: No crank!
"The Safety Switch"...sure as $&@t that's the issue. Well one good thing is the entire starter system has been thoroughly gone through, cleaned, and confirmed. Thanks cdowns! Dang Easter shops closed early
Re: No crank!
I once had a local "Irish" auto parts store tell me my starter was good. It wasn't:devil: ......Jus sayin;)
