Correct steering column brackets?
I am replacing the 80's style steering column in my truck back to the original column, due to the current column not being installed with the highest quality. However before i buy the new column, I need all the original brackets for my 69 C-10. I see them on Ebay and wanted to make sure these are the correct brackets for what i need before i pull the trigger and buy em. Thank you in advance!
Re: Correct steering column brackets?
Yep those all look like the right ones to me.:chevy:
Ok, thanks!
I have a 71 blazer I got apart. Does anyone no were I can get the mounting hardware for steering column under dash?
Posted via Mobile Device |
jjlett69 exactly what I was looking for. Can you or anyone else tell me what sized mounting hardware (nuts / bolts) get used in those brackets and where?
Thanks Mike |
Try the truck or Blazer classifieds. You can't post a "Want To Buy" unless you are a "Premium" member but if you see something for sale you can buy it. A lot of guys parting trucks & Blazers..... LockDoc |
Kind of depends on what year. The '67 & '68's are a little different because of the emergency brake location.. Most of the bolts are 5/16 x 3/4 or 1 inch. LockDoc |
