1970 C10 AWD Project
2 Attachment(s)
This is My AWD c10 Project
Re: 1970 C10 AWD Project
C10
Interesting
What is parts availability like in Puerto Rico? |
I had a good friend who lived part time in P.R. Its a mix of US and Import cars so I knew some guys with old Chevy's, and others with Import-only diesels that we can't get in the mainland.
You guys still doing the dune-climbs and stuff out in the sand? |
Engine in place
pics:ito:
Fugg. YES!
Very cool. |
what front suspension parts are you using?
Sweet build
how did you mount up the suburban front axle/suspension? I have been trying to find a drivers side drop dana 44, but they are not real common apparently. so this would be another option.
thx |
Twin turbo, LS, AWD C10.......hell yes! Fricking sweet!!!
Rob |
What hub did you use to get the 5 lug pattern or did you have it redrilled? Any other pictures of the front suspension? Pretty slick project!
Cool build. Love the twin blow dryers:metal:
2 Attachment(s)
Wheel Height
what AWD t-case are you using? NVG-149?
Yes!! NV 149 For the Moment, But im working on GM 246 this unit is servo motor controlled so mean i can use AWD just when i needed by a flip of button or automatic mode.
Very interesting build.....I like it. :thumbs:
I know you don't have good parts availability there in PR, but I wonder if an AWD Astro/Safari hub would bolt up to the spindle and fit the axle. Those are already 5 x 5. |
not familiar with the GM246 unit.....but know that the NVG-149 is one b@d@$$ AWD unit. The torque split is awesome and they can handle all kinds of HP. Guys putting all kinds of power to them....like a Gear Vendors OD. I owned a '01 Sierra C3 and wish I had never let it go. Amazing traction in nearly any scenario....pulled a Mustang uphill on slick ice and never spun a wheel...on stock Michelins....then found out he had is e-brake on the whole time and that I was dragging vs pulling him. LOL! Just one example.
Hi, ive a Silverado SS with twin Turbo Setup with 800 Hp at the wheels it currenly have an nv 149 behind of 4l80e with input shaft adapter we have lot troubles with the vicous coupler to handle big power, i dont know if in the market have aftermarket vicous coupling can handle more power. |
Wow.....I think your the 1st I've heard that's found the limits of one.
