stepside bed question
bought a swb stepside. the taillights were gone and I am trying to put stock taillights back on it. there are threaded holes for taillights and backup lights. anybody know what size the bolts are?cant find them in any catalogs. also do all bolts that hold bed to frame go through the wood or are there any other bolts that attach to frame?any help is appreciated.
Re: stepside bed question
The bolts go thru wood and rails to hold it to the frame 4 in front and 4 in rear. My taillight bolts were replaced with self starters so I cant help you there.
thanks . I got a new set of bed bolts just making sure that was all that held it on.
still trying to find out what kind of bolt holds the stock taillights on stepside bed. went to hardware store and nothing there will thread in to hole. are they the bolts with the tapered end similar to those that hold inner fenders? a picture would really help
I just took another step side bed apart and those bolts are 5/16 and take a 1/2" wrench, not 3/8 bolts that take a 9/16" wrench like I said the first time I replied - my bad.
My guess is that someone has cross threaded the holes that have a factory nut welded behind them and now the bolts don't want to fit. Have you tried to run a 5/16" 18 tap into the welded nut to clean out the threads? Of course, some of those bolts are just bolts and nuts through blank holes and some have threaded holes - it is a mixture. I could send you some of the old bolts out of one of the beds I have disassembled if that would help you any. Jay |
If you send me your email address I will send you some photos of the bed parts and bolts that I have. Jay |
If I can remember to, I'll get some pics of my stepside also.
*The LMC taillights and reverse lights I ordered were perfect in every respect. I wish I could say that about the rest of the things I bought from them. |
finally got my taillights on. the threads were screwed up in the mounting holes. made some bolts work. thanks for all the help. sometimes the smallest thing can get your blood pressure up. THANKS FOR YOUR TIME.
Terrific! Determination and perseverance are your best tools sometimes. Jay |
