Gas Tank sending Unit
I notice a lot of the after market gas tank sending units come in two flavors.
30ohm and 90ohm. What the stock gauge use? |
Re: Gas Tank sending Unit
I'm curious as well
I believe they are 90 ohms.
I measured it with an ohmmeter across the entire sweep, as I also did with the temp sender on the stove. PM me if you want the data.
They are 90ohm
