BB shroud w/2-speed fan installed
I've gotten quite a few messages about doing a few of these and since there seems to be some interest in them, I have a couple I'll sell so if you want a really easy way to upgrade to a stout electric fan while retaining a stock GM shroud, I have what you need. I'm not asking a fortune for these....I have more time in labor than anything but these come with a 2-speed relay control harness already installed-you only have to bolt it up using your existing top radiator support plate and:
1.) Run a +12V lead to the firewall (or battery) 2.) Run an ignition source wire 3.) Chassis ground the fan to your existing ground near the battery 4.) Run a lead to your AC low pressure switch wire 5.) Run a lead for a low temp switch 6.) Run a lead for a high temp switch Done!! Asking $150 plus shipping for this setup to anybody interested in one! PM quick if you want or post first come first served here! |
