64-66 Gauges with Tach
2 Attachment(s)
Nice factory Tach dash setup worked when I took it out.
275 plus shipping |
Re: 64-66 Gauges with Tach
I'll take it if still available.
sorry, may have jumped the gun... does the tach require a transmitter to work in '66 C10?
thanks |
I don't know, pulled it out of a running 66 farm truck, everything worked fine 2 years ago, was going to use it myself, but going with a ls swap.
It worked on my old 66 farm truck just fine. |
You'd need the model # of the back of the tachometer to know if it needs a box or not.
Where is this "model #" ? I'm sure this will come up again.
Estimate for shipping to 29662?
If it's in fact a '64-66 then it does not need a transmitter. It is also likely for an 8, not 6 cylinder. Take the cover off the back of the cluster and the tach will probably look like this original '65 8 cyl :
Shipping to 29662, about 21 bucks.
bump
250 plus shipping......
SOLD, thanks.
