Will fuel sending unit out of a 72 fit a 67?
I need a in tank fuel sending unit for my 67 c-10.I have a 72 GMC parts truck that may have a good sending unit but before I even pull it will it work?My 67 only has 1 fuel line going to unit and the 72 has 2 fuel lines and they come out of the tank at a different angle than the 67.
Re: Will fuel sending unit out of a 72 fit a 67?
yes ohm is the same 0-90 . the 72 has is vented that is why the second line . I just pulled my 69 fuel tank out today , nice clean tank and has single non vented sending unit . if you want the sending unit , you pay the shipping and I box it up and send it to you .
I believe the fitting on the sender is also different too. You'll just have to buy a new fuel line with the correct fitting.
