Hydraulic clutch help
I'm in need of help mounting master cylinder for my cummins conversion. Any pics or pointer would be great. I've got the factory twist style master cylinder from dodge .
Matt |
Re: Hydraulic clutch help
Are you on Facebook? There is a page called GM Square Body Cummin's Swap that has several guys who have swapped trucks. From what I'm seeing there they are using a Ford Master Cylinder NAPA part # 72176, and having a line made to join them to the Dodge Slave cylinder.
I used the bracket that was in the firewall on my 93 ram. Unbolted it and bolted it directly to the frame of my truck . I know that won't work for your app but I'm sure you can fit the bracket in there somewhere.
I have a treat waiting at the shop for you. I need to put it through QA still, but...
