white roof no cab trim
Looking for some examples of white cab roof without the dividing trim. Trying to see how others may have worked around the lack of trim. My truck has no moldings/trim and I would like to paint roof white when I paint it.
Re: white roof no cab trim
My old gmc
Close up. Yes I know the wheels were hideous
4 Attachment(s)
Not perfect, but that's how I did it. |
That turned out nice cooper.
In my opinion white vans are a signature of this era really sets them off I would think even some of the wide pin striping material would do the trick too |
That does look good cooperhw. Thanks
Here's how I ran it....totally winged it. Thinking a red pinstripe may be in order once the hellish wet sanding is done.
Posted via Mobile Device |
I do have the advantage of a short headache rack to confuse the eye across the back...leaving just the cab radii on either side but I think I'd do it again this way. Appreciate the compliment and good luck.
Just wing it! Posted via Mobile Device |
One more pre headache rack for additional perspective
Mar-K sell a kit to install the cab trim on non-trim trucks.
http://www.mar-k.com/Catalog/catalog.aspx -------------------------------------------------------------------------------- Mouldings-Rear Cab Screw-in Stud C100339 - Mouldings-Rear Cab Screw-in Stud Small screw-in studs are available for use on trucks without the original welded studs for attachment of the Rear Cab mouldings. This piece is not included with the Rear Cab moldings and must be ordered separately. Twelve studs required for installation of both Rear Cab mouldings. Part Number: C100339 |
