Which oil pan?
I've got a new project. A 68 SWB fleetside with a 5.3 LS engine in it. The stock oil pan is too low and I'm planning on replacing it with a Holley 302-1 or a 302-2 or something better if there is one. Anybody have any ideas?
Thanks. |
Re: Which oil pan?
I cant answer your question but Im going to move this to the Ls section for you. The guys there will be able to help you out.
Re: Which oil pan?
The H3 pan may be a ton cheaper and I know the S-10 guys are using them for that type of truck so it should be plenty for yours. Jim
Re: Which oil pan?
The f body pan was $300 to my door. Read up on the Holley pans, you need to modify the windage tray which scares me
Re: Which oil pan?
Re: Which oil pan?
ooops
Re: Which oil pan?
Re: Which oil pan?
The "H3" pan is another name for something called the LH8 or "Hot Rod" Pan. Allow me to expound: The Hummer H3 got made for a few end-run years in a model called the Alpha, which replaced the 3.7 5cylinder with a setup for the 5.3 but still retaining hummers AWD system. When GM did that version of the truck, they approached it much like a hot rodder would, and simply went into the GM parts locker for a solution.
GM had started selling crate motors and replacement motors by that time, and they had an existing part # in their "Hot Rod Swap Kit" which, sure enough, just happen to be the SAME pan that fits the Hummer. For most purposes, its the universal solution. It WILL still hang about to crossmember level, but not below, and clear the crossmember just fine. There are multiple sources, but searches for "GM Hot Rod Pan, LH8 Pan, or H3 Alpha Pan" will all return the same part #'s. I suggest checking places like Nalley (which sells GM part #'s for a few $$ less than most local dealers and no tax). |
Re: Which oil pan?
Could always look at ebay for a CTSV pan. Picked up a new one including windage tray and dipstick for $100 + the ride.
Not fitted the engine yet but looks like it will give plenty of clearance over the stock truck one. P.:D |
Re: Which oil pan?
Incorrect info removed at request of the poster.
Re: Which oil pan?
Thanks for all the help everyone. The muscle car pan kit at jegs for 149.00 with all I need sure beats 350 for the Holley 302-2. The Holley looks nicer and holds 3/4 of a qt. more oil but when you're on a budget........
Thanks again. |
Re: Which oil pan?
The GM muscle car pan is a great deal when you need to replace a truck pan. Unfortunately, it's not much help for gaining clearance over the truck pan. The H3/muscle car pan is just over 1/2 shallower than a truck pan (7.75" vs 8.34"). For comparison, a CTS-V pan is 7" deep, and F-Body pan is 5.62" and the Holley 302-1 is 5.71".
Here's a link to various oil pan dimensions: http://www.dirtydingo.com/shop/pages.php?pID=8&CDpath=0 And a comparison of the Holley pan to the H3 pan: https://lh3.googleusercontent.com/-d...Comparison.jpg |
Re: Which oil pan?
Re: Which oil pan?
I installed the "F" body pan and made my own motor mount brackets using the organ donor 2001 ls mounts. I chose the "F" body pan for the additional reason it's the thinnest up front below the timing cover. My steering linkage center section ( stock linkage) almost rubs the pan as it passes under the front lip. The clearance is 1/4" max. The low sump area is still higher than the factory cross member by maybe 1/2".
Re: Which oil pan?
Jimmy,
I just did this and I used a stock truck oil pan. I can take picture tonight and post them but the truck pan is just fine and fits like a glove. Personally I don't see any reason to go with the lower profile pan. Have you already installed your engine and realized that you want a lower profile pan? If not, and if you are on a budget, I'll say go with stock and spend the money elsewhere. Believe me, there will be more i$$ue$ that will come along with this swap. |
Re: Which oil pan?
Re: Which oil pan?
This is true. I just talked to a guy a week ago Sunday that broke his oil pan because it hung lower than his cross member. He said that it was not a fun experience...... Also had a guy looking at my '67 Panel when I was putting gas in it and while talking to him he mentioned that he had his truck oil pan sectioned and welded back together to shorten it. Not sure how that would work but he said he hadn't had any trouble with it. I would think you would have to get a shorter pickup tube for the oil pump. Dunno what they look like inside the pan. LockDoc |
Re: Which oil pan?
Oh ok, I now see the reasoning behind the question as a lot of people likes to lower these truck. Mine sits between 1-2 higher since I have HD suspension so probably that is why it was a noticeable issue to me. I'll check when I get home tonight how mine sits and I'll also post some pictures. |
Re: Which oil pan?
As for the pickup tube, its possible to modify one, but its crucial that the pickup tube rests at the lowest/sump point. As long as it doesn't have any kinks or an excessive length, it'll work just fine. |
Re: Which oil pan?
Thanks everyone for all the help and conversation. It really helps listening to all the suggestions. My 68 has been dropped 2-1/2 inches. The oil pan hangs about 2-1/2 inches below the cross member and about 2-1/2 to 3 inches from the road. I think the Holley pan may be the best choice for me.
Re: Which oil pan?
Thanks for the input on that. I guess if a guy shortened the tube the same amount as the section he would be good to go. I am going to be picking up a '01 truck 5.3 and all matching components in the next couple of days so that's probably what I will do.... LockDoc |
Re: Which oil pan?
It's funny that I never paid attention to the oil pan when I installed the engine. Mine sticks about 2" also and I am not comfortable with that, even though my truck has a lot of ground clearance. I hope to build a skid plate soon that will provide protection to the pan, last thing I want is a hole in that thing.
Re: Which oil pan?
Cadillac CTSV pan...
Re: Which oil pan?
Does anybody know what dipstick and tube is used with the Holley pan? My dipstick is the wrong one for the motor.
Thanks. |
Re: Which oil pan?
