"convenience" center
Hi all,
I'm popping the horn/dim fuse on my 90 burb and I'm wondering where did GM hide the relay. Diagram says it's in the "convenience" center. The only thing I know is it's inconvenient. |
Re: "convenience" center
If its anything like the older square-body trucks and suvs, its above the gas pedal on a bracket with door chime buzzer and in some cases the hazard flasher is in that same center. hope this helps. good luck, wiring issues are a pain in the ass.
Yes they are.
Thanks BigSteve. Yeah it should be just like the early square bodies.. I'll dig into it. thanks! |
