shortened hubs
I have a 71 4wd blazer and saw a picture of a blazer with shorter hubs on the front. I have a dana 44 which im sure most of yas do too. This truck had a dana 44. how do you get shorter hubs so it doesnt stick out so much?
Re: shortened hubs
Photoshop.;)
Re: shortened hubs
The picture you saw might have been of a newer Dana 44 with internal hubs. Your Dana 44 might be an older version that was swapped in, with external hubs, which are longer. The truck in the picture might also be running a wider rim, which would make the hub look like it is shorter.
Re: shortened hubs
Is there a kit that can covert the hubs to internal since I have the older style?
Re: shortened hubs
