67 C10 Door Alignment
Both my passenger and driver door on my 67 C10 are rubbing on rocker when door is 3/4 way open. The bottom inner corner on each door are rubbing the paint of the rocker panel. I loosened up the bolts on the door with a jack under the door and didn't have much luck. Wondering if others experienced this issue and what is the best approach. I haven't touched the bolts on the cab to hinge. :chevy:
Re: 67 C10 Door Alignment
does the door shut and latch correctly
Yes, it appears to be shutting and latching correctly
Were new rockers installed? maybe over the top of the old ones or welded too high?
I welded in new rocker panels, they were a little high, but I was
able to "massage" them to fit my my doors with a large rubber mallet. |
Take a 4x4 block or 2x4 if you can't come with the 4x4, oh say a section 18 inches long place on the rocker and whack it with a hammer. I know this sounds awful but believe me it happens in body shops all over the world every day that a piece of wood and a large hammer is used to manipulate metal to where it needs to be. If the door is catching the rocker the bottom could get folded in in an extreme case.
Thanks! It does appear the PO replaced the rockers. Hard to say whether the old ones were removed or not. The bottom of rocker seems to be aligned pretty good. Before I get out the hammer and a block of wood, would adjusting the bolts that attach the hinge to the body help me in this scenario at all?
