Dodge d60 questions
Does any one know if it is possible to change dodge external hub dana 60 outers to chevy internal hub outers? And if so what all has to be changed?
Re: Dodge d60 questions
You'll need the hub ,rotor and lockouts. The Gm will have 9/16 studs.
Are the dodge and chevy spindles the same
Yes as well as the outter stub shaft.
Thank you!
Later years like 93 and older first Gen Cummins trucks used the internal lock outs as. Just a thought to broaden the search if you don't already have some located.
Thank you. They have the same brakes as gm as well right
