GMC Front sheet metal assembly
2 Attachment(s)
I hope you guys can help....
I have a 57 GMC 100 truck that I got as project, completely dismantled. I am currently assembling the front end sheet metal. It's all bolted together, apart from the where the forward tops of the inner wings meet the radiator bulkhead. I can't figure out how the top of the bulkhead bolts the inner wings. See gaps on the attached pics. Have I got some brackets missing? Thanks in anticipation Roarinrat |
Re: GMC Front sheet metal assembly
5 Attachment(s)
Ok here's your bracket , support rod and the rest of the radiator bridge.
Also note the large brace from the cowl to the frame, this may be only a 4x4 thing as this is a 4x4. |
and the right front
I have a Canadian 57 gmc and I don't remember my rad support looking like that. were US models different or was there a mid year change?
1955(2nd Series)-57 GM Truck EDP Coated Radiator Support
Product # T70647 mine looks like this, sorry, pic didn't come. if you check google images it shows 2 distinct types. |
My 56 GMC looks like this also.
Pictures tell it all. I haven't got those brackets, will have to make them.
Thanks for your help. |
Does anyone have a pair of GMC fender tie brackets they can sell me?
Are they the same on Chevy trucks? Thanks in anticipation Steve |
Makes for interesting comparisons for sure! |
From what I could see your truck is modified, judging by the bit of valve cover visible. Why don't you just make up some? I'm sure that would be a heck of a lot cheaper! Hope you get something figured out! DAC |
The Chevy Radiator support has a bolt from the inner fender to the end of the rad support and has a captured nut in the rad support.
Here is a picture of my '56 Chevy rad support, you can see there is no "T" shaped bracket and the rad support is a completely different design then the GMC. |
