Fitler on Power Steering Return Line?
I have a '71 GMC Jimmy with a 350 V8. It has P/S. I live in the desert with a lot of fine-grained sand getting in everything. Can I run a filter on the 3/8 fuel-type hose that runs from the P/S Pump to the gear box? I'm thinking a fuel filter might work. This is on the low pressure side. BTW, which way does it flow?
My gear box is making a whirring noise. I keep adding fluid, but it comes back. Today I noticed some abrasion on the LP hose where it rubs on the frame. Could be my leak. Since I gotta run a new low pressure hose, I might just put the filter in as well. Good or bad idea? :gmc2: I mean FILTER. |
Re: Fitler on Power Steering Return Line?
It's done all the time. Your local NAPA store has a filter specific just for this.
Good to know that it can be done!
