Radiator Re-core - How much should it cost?
How much should it cost to re-core a 4 row OEM radiator (1972)? I am getting a price of $450. That sounds high to me. Thanks.
Re: Radiator Re-core - How much should it cost?
I bought a new one for a lot less than that.
Yep, a new one can be had for much less. I would not re-core this one for $450, but before I run it around town for more quotes I want to know if the $450 price is close to what someone should expect to pay.
I had my original re-cored and rodded for $80. Local radiator shop.
I was quoted almost 600 to do mine a few years ago i just got an all aluminum one
I had one done this spring and it cost three hundred bucks.
I have had one done over a year ago it was about 430 bucks. So not a bad price. Deal with mine was an industrial grade forklift core, its thicker material by a couple of thousandths.
The cores I am speaking of come out of Canada. |
I just had mine quoted $350 for a 2 row in San Jose CA. I’ll be going aluminum.
I had a 2 core turned into a 3 core with restrictors for about $350, that's Canadian dollars though. I think $400 US is a little high, even for a 4 core.
I would recommend recoring to anyone thinking about buying new. |
I was quoted between $350 and $375 to recore a two row core a while back. $450 may not be that far out of line for a four row core.
I just bought a new 4 core copper/brass radiator for $397.30 with all new brackets and pads from LMC including shipping for my 69 Blazer restoration. It is a nice looking stock unit. I had a stock 3 core that would have undoubtedly needed to be worked on. Did the same when I restored two other trucks and my GTO's. I like new and stock appearance, especially with the cooling system - new hoses, water pump, thermostat, fan clutch, and a good shroud.
Gary |
It's expensive because there are limited suppliers for the cores now. What ever you do don't throw that 4 row away. The tanks are worth money. Someone will need them for restoration at some point. They don't reproduce them.
I had found a place in California who still built the factory Harrison radiators With me living in Alaska and moving to Reno Nevada , I opted to not spend the $350.00 for a recore and $425.00 for some knock off cheepo , I went to this company in California and for a Desert 4 core radiator with automatic transmission fittings delivered to me here in Reno was under $400.00. Just had to round up some big block upper radiator brackets and I was golden. The truck runs all day long at 190.
Vic |
I think I paid about $100 about five years ago to have a radiator guy build a two row with proper tanks and a good core (see thread here).
Radiator shops are dying out though.... :mad: |
