tearing into my 62
I couldn’t stand it any longer, pulled the ol work truck out of the barn and ripped out the rodent smelly interior. Need to replace flooring and rockers , and would like to relocate gas tank . Any advice on under the bed tanks would be appreciated. I really don;t want to spend 500 on some fancy fuel cell.I am not a purist and may turn this into ratrod.:waah:
Re: tearing into my 62
X frame under your truck? Width on x frame is wider in the rear....I used 93 Caprice wagon 22 gallon poly tank...made hangers..etc. Gives you the option of using in tank pump or just removing it...sending unit is different OHM s...
