toe in question.
I just replaced my tie rods with some n.o.s. TRW ends I bought last year at a swap meet. I'm going to take it in for aliniment anyways but I would like to have the toe in set some what close to make the 30 mile trip. I looked up previous threads on this and from what I've found and what I did was set the toe in at 3/16 from center of treads on tire. Is this correct for radial tires which I have or is this set up fo bais ply tires. Guy at work has me questioning this so I thought I would ask you guys . My fronts are 32x11.50r15. If that matters
Re: toe in question.
That will get you there , and not tear up tires , 1/8 inch is what my alignment guy suggested
Thanks for the quick reply. I'll actually adjust to 1/8 for the trip to the alignment shop. I know it's not going to happen but for self satisfaction it would be cool to pull it in there and they say they don't have to adjust anything lol.
You can do an alignment yourself with string. I did and found my frame is bent. I opened a big can of worms, but check out the video link in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=703198 |
had mine at 3/4 out for one short ride , it was interesting to say the least
1/16" toe in on each side is a good number to shoot for. I did some suspension work on mine including drop spindles, 4" springs in back and stock height springs in the front and took it for an alignment and after $200 the alignment was terrible. I bought a bubble level alignment tool for $129 and did it myself and it is beautiful.
My setting right and left are -1* camber and +3.5* caster with 1/8"total toe. I have power steering, if manual steering I would set caster to +1.5* and see how it works, +caster will make the truck not want to turn and help improve return to center but can make it hard to turn in parking lots. I can drive down the highway at 70mph with no hands on the wheel now and have no noticeable tire wear in over 1000 miles. I have been checking because the shop alignment was eating tires. I forgot to write down the numbers I started with. the largest shim stack I have is 7/16" (3x 1/8" and 1x 1/16") |
